2 Pages<12
#11 Posted : Tuesday, May 13, 2008 8:55:56 PM(UTC)
Robert,
Looks like the touch pad gone bad too.
- The part number for the touch pad (aka membrane switch) is AP368491
robert22
#12 Posted : Thursday, May 15, 2008 4:45:29 AM(UTC)
robert22
Robert,
Thanks Gene.
Bob
robert22
#13 Posted : Friday, May 16, 2008 11:42:01 AM(UTC)
robert22
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
robert22
#14 Posted : Friday, May 16, 2008 11:53:19 AM(UTC)
robert22
robert22
#15 Posted : Friday, May 16, 2008 11:54:49 AM(UTC)
robert22
Gene,
I received the new touch pad (membrane) today and installed it. It works great. Everything is back to normal. Thanks again for your help.
Regards,
Bob
#16 Posted : Friday, May 16, 2008 2:39:47 PM(UTC)
Bob,
I'm glad you were able to fix it.
r26290
#17 Posted : Tuesday, January 6, 2009 1:40:35 PM(UTC)
r26290
Hi Gene,
I have a jenn air stove. I just ordered and replaced the electronic display. At first it seemed to work fine, however the "0" would not work. I disassembled and tryed to clean the membrane ribbon connection with scotchbrite. Now nothing except the timer works. This pad did seem to work fine before I did anything. Does the membrane need to be replaced, or is it possible that the ribbon connection may need to be cleaned with something like contact cleaner?
2 Pages<12
