davebryant
#1 Posted : Thursday, May 13, 2010 7:24:38 AM(UTC)
davebryant
I trying to place a power browser to the compressor.But on the compressor the connector holes reverse 1 up top 2 on bottom but on the compressor the 2 holes are up top and 1 down the bottom.Which plug is the run,start and common.
davebryant
#2 Posted : Thursday, May 13, 2010 7:33:11 AM(UTC)
davebryant
Model #GFU21M6AW7 Serial#WB51834956.Just need to know how the plug are set up with the 2 up top and 1 down the bottom.Start,Run and Common.
#3 Posted : Thursday, May 13, 2010 12:00:24 PM(UTC)
You can figure it out by measuring the resistance between the pins. Resistance between the COM and RUN should be more than between the COM and START. Resistance between the RUN and START = resistance between COM & RUN + COM & START.
Be advised that a power booster can damage the compressor motor. It's better to use the original start device.
- The start device Part number: AP2113688
