ButlerFamily
#1 Posted : Tuesday, May 11, 2010 7:20:28 AM(UTC)
ButlerFamily
My dryer just stop running, will not start at all. I dont know if it is the motor or not. I push in the start button and get nothing.
magician59
#2 Posted : Tuesday, May 11, 2010 8:39:25 AM(UTC)
magician59
Check the outlet. You should have 240VAC. It won't be perfect, but should be reasonably close.
ButlerFamily
#3 Posted : Tuesday, May 11, 2010 9:56:12 AM(UTC)
ButlerFamily
my dryer still do not start, I checked the outlet and everything seems to be ok on that end. It worked 2 days ago. what else can i check?
magician59
#4 Posted : Tuesday, May 11, 2010 11:45:42 AM(UTC)
magician59
The components to check are: Door switch, thermostats, thermal fuse, timer, and start switch. The timer is the least common of all these items to fail. All the others can be checked for continuity.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
