Replacement parts for MAYTAG PDET920AYW Dryer - Ele | AppliancePartsPros.comHere is the tech sheet
http://www.servicematters.com/maytag_library/docs/16027535.pdfAnd a manual
http://www.servicematters.com/maytag_library/docs/16026315.pdf [COLOR="Blue"]
I have taken it apart and checked the contiunity with a GE contiunity tester (from Walmart) I am no repair man and lack basic common knowledge on how these things work.[/COLOR]
At one time none of us had basic knowledge so you are just a little behind us.
Once you get this fixed you will have some.
There are plenty of folks here to help you along.
Below is a good site with some basic info.
http://www.applianceaid.com/dryers.html I am not a big fan of continuity checkers you are much better off with a multimeter, then you can see actual resistances and voltages.
[COLOR="Blue"]
I tried to bypass what I believe to be the thermal fuse but that did not work.[/COLOR]
Thermal fuse is Item 6 in Section 1 of the parts.
[COLOR="Blue"]I have checked the continuity on everything that I can think of but I am not sure if I am doing right or not. The light comes on so I assume that I am. I checked the wall outlet and it lit up as well with a outlet tester. [/COLOR]
Did this check both sides of the line.
In case you do not know the 240 volts is made up of 2 120 volt (L1 to Neutral and L2 to Neutral) supplies that are 180 degrees out of phase. Basically when one supply is at negative 120, the other is at positive 120 so if you measure between the two you get 240 volts (L1 to L2). Only the heater uses this 240, the motor and timer use half the line (120 volts).
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
You may want to not do the following as you are a newbee and it is dangerous.
Be careful as 240 volts is lethal !!!
[COLOR="Blue"]The push start knob seems to be loose or bent, or wobbly (in short it doesn't feel like it used to) could this be it?[/COLOR]
It is a possibility.
Unplug the unit.
Unplug the wires from one side of the switch.
Check it with a meter, should be infinite ohms (open).
Then activate it, should go to ) ohms (closed).
[COLOR="Blue"]Could I have messed something up when putting it back togather from replacing the heating element that would allow it to work for a while before messing it up?[/COLOR]
Could be.
Check for signs of what the pop was re: burned off wire, soot spot or a weld mark.
Also check the heating coil sometimes the element can get hot, sag and touch the case.
Below is the circuit path for starting the unit:
N neutral , WH white wire , DOOR SWITCH closed contacts , YL/BK yellow/black wire , PUSH TO START SWITCH S/M , WH/BK white/black wire , DRIVE MOTOR note it is shown in the already running position , START and RUN motor windings , GY gray wire , THERMAL FUSE , timer contacts 3 , YL yellow wire , L1 line one.
It will also let you check the voltage.
