napradoc
#1 Posted : Saturday, May 10, 2008 5:26:49 AM(UTC)
napradoc
Trying to remove old motor.
I can't seem to access the blower side of the motor.
I can only access the motor through the lower panel door. I have not been able to remove the door panel yet, the screws seem to be frozen, and I don't want to strip the heads.
I can reach behind the motor(blindly) but can't seem to loosen anything.
I would appreciate any help before my children begin learning new vocabulary words!!!
Steve
SublimeMasterJW
#2 Posted : Saturday, May 10, 2008 6:07:25 AM(UTC)
SublimeMasterJW
If this is the one I think it is (your model number don't jive so I gotta guess.) On this model it is simular to a washer that has to have the case removed. In that you need to flip up the control panel and remove 3 screws holding the top on. remove the top then the front panel can be taken off. Do you have a picture? Check your model number so I can look it up.
napradoc
#3 Posted : Saturday, May 10, 2008 6:16:25 AM(UTC)
napradoc
Sublimemaster,
The model # is 1106808810W00 and it is a Kenmore.
There were two screws at the top of the door panel and after you open the door there are three screws on each side of the door. I think only the lower two are securing the panel, but they are really stuck.
I'm not normally stumped by these things, but this one has got me.
Steve
SublimeMasterJW
#4 Posted : Saturday, May 10, 2008 2:03:51 PM(UTC)
SublimeMasterJW
Do you have pictures we can look at?
Guest (4)
