AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Irritation Progressing To First Phase Of Anger
Trying to remove old motor. I can't seem to access the blower side of the motor. I can only access the motor through the lower panel door. I have not been able to remove the door panel yet, the screws seem to be frozen, and I don't want to strip the heads. I can reach behind the motor(blindly) but can't seem to loosen anything. I would appreciate any help before my children begin learning new vocabulary words!!!
Steve
If this is the one I think it is (your model number don't jive so I gotta guess.) On this model it is simular to a washer that has to have the case removed. In that you need to flip up the control panel and remove 3 screws holding the top on. remove the top then the front panel can be taken off. Do you have a picture? Check your model number so I can look it up.
Sublimemaster,
The model # is 1106808810W00 and it is a Kenmore. There were two screws at the top of the door panel and after you open the door there are three screws on each side of the door. I think only the lower two are securing the panel, but they are really stuck. I'm not normally stumped by these things, but this one has got me.
Steve
Do you have pictures we can look at?
Dryer Repair
