coysan
#1 Posted : Saturday, May 10, 2008 5:13:52 AM(UTC)
coysan
Dryer stopped heating. Relaced coil-heater; thermal limiter and thermostat-safety. Still no heat any suggestions as to what next?
SublimeMasterJW
#2 Posted : Saturday, May 10, 2008 6:14:34 AM(UTC)
SublimeMasterJW
With the power disconnected trace the thick red wire from the heater up to the timer. At the terminal where that red heater wire connects to the timer is where I suspect the problem is. Remove the wire and check it with a meter. Set the timer to a place where you know it was working before and check between this terminal and all the others on the timer. Somewhere along the way you should get a continuity reading. If you cannot get a reading then that timer is fried.
misterfixall
#3 Posted: : Saturday, May 10, 2008 6:41:29 PM(UTC)
misterfixall
did you check with your meter, if you have on ,whether youare getting 240 volts coming to dryer. if so there should be a wiring diagram in control panel. that will show you the contacts that would be closed in timer ,you need to set your timer to continuity to do this test .unplug dryer first .set timer to minute cycle
coysan
#4 Posted : Thursday, May 15, 2008 3:39:54 AM(UTC)
coysan
tks I'll try! out of town sorry 4 late reply
douglas j. hoffman
#5 Posted : Wednesday, September 3, 2008 4:54:55 PM(UTC)
douglas j. hoffman
I will write again if I find this solution
Bosch electric dryer model WTVC6330US/10FD9007 (Dryer Repair)
by Guest 6/11/2024 9:40:58 AM(UTC)
AMANA electric dryer model NED4600YQ0 (Dryer Repair)
by Guest 5/31/2024 3:29:23 PM(UTC)
Amana Electric dryer timer for model LEA50AL (Dryer Repair)
by Guest 5/20/2024 5:37:01 AM(UTC)
Amana electric dryer not working (Dryer Repair)
by Guest 5/3/2024 10:43:01 AM(UTC)
Kenmore Electric Dryer 110.65132411 (Dryer Repair)
by Guest 5/1/2024 5:58:30 AM(UTC)
Maytag electric dryer model MDE6400AYQ (Dryer Repair)
by Guest 3/25/2024 10:05:21 AM(UTC)
Electric Dryer Amana NED7300WW1 (Dryer Repair)
by AlexanderK 3/13/2024 1:37:06 PM(UTC)
Maytag electric dryer model LDE9306ACE (Dryer Repair)
by Guest 3/7/2024 9:11:14 AM(UTC)
Speed Queen electric dryer model LES17AWF (Dryer Repair)
by Guest 3/5/2024 10:42:09 AM(UTC)
LG DLEX5170V electric dryer won't start (Dryer Repair)
by Guest 2/23/2024 11:17:20 AM(UTC)
Kenmore electric dryer typical model 110.68522700 (Dryer Repair)
by Guest 2/22/2024 10:10:02 AM(UTC)
Maytag Electric dryer model MEDC300XW0 (Dryer Repair)
by Guest 2/6/2024 1:56:33 PM(UTC)
Maytag electric dryer blower wheel wear (Dryer Repair)
by Guest 1/1/2024 7:44:11 AM(UTC)
Speed Queen electric dryer model ADE3LRG8171TWoi (Dryer Repair)
by Guest 11/26/2023 2:53:33 AM(UTC)
Kenmore electric dryer model 110.68622700 (Dryer Repair)
by Guest 11/12/2023 6:47:37 PM(UTC)
