kenbary
#1 Posted : Saturday, May 1, 2010 6:49:28 PM(UTC)
kenbary
dryer was squeeling, replaced rear bearing assembly and belt,but now scraping noise
I picked up new front bearing glides (teflon strips) but cant find where it put them. But the front bearing or drum support has some cracked plastic missing. I see one remaing brass glide on left side , but right side is the cracked part. If I ordered a new front bearing or support I dont know if it will fix it, will I know where to put the teflon glides. getting frustrated. out 75 bucks so far. Dont know why they call that plastic half of moon a front bearing, support yes. Can anyone help me?
kenbary@comcast.net
sidfink43
#2 Posted : Monday, May 3, 2010 11:58:00 AM(UTC)
sidfink43
Well I don't know why they call it a bearing either. Look, we cannot guarantee any recomended repair will work because we are not there to actually see the problem. We can only give you our best recomentation.
In this case, replace the glides in the "bearing" first before you order a new bearing. The glides have tabs on them and they go just offset of the top of the bearing. Click on your model number to see an exploded view of your machine to see if that will help.
Also check your tension pulley to see that it is not the cause of the problem and make sure the belt is on correctly and that the drum is seated correctly in the new bearing.
That's all I got
kenbary
#3 Posted : Monday, May 3, 2010 2:36:17 PM(UTC)
kenbary
That's all I got
Thanks, After getting the glides, I realized there was only one spot left to put them. The plastic "front Bearing" , what a bitch to get off, was cracked . ordered the new one , waiting on it. I see now that the front rim supports half of the drums weight.
thanks
ken
kenbary
#4 Posted : Thursday, May 6, 2010 3:34:06 AM(UTC)
kenbary
Now replaced the front bearing and glides. Everything looks good except when running it makes a pop or bang at each reveloution. I put on the new bearing kit and grounding strap exactly how the old one was, but the new grounding strap did not have a rubber pad at the end like the old one.
Could that be the noise?
:mad:
kenbary
sidfink43
#5 Posted : Thursday, May 6, 2010 3:42:15 AM(UTC)
sidfink43
I don't thank so, try checking, and if necessary replacing the tension pulley and belt.
I know you have spent a lot of money, but it is still far less than a new machine or a service call that may not have even fixed things.
GE Dryer won't stay on (Dryer Repair)
by Guest 6/21/2024 2:16:20 PM(UTC)
Ge dryer will not stay on (Dryer Repair)
by Guest 5/10/2024 3:25:16 PM(UTC)
GE dryer timer issue (Dryer Repair)
by Guest 5/8/2024 11:47:16 AM(UTC)
GE Dryer Timer and Housing (Dryer Repair)
by Guest 3/25/2024 7:47:59 AM(UTC)
Humming/Rattle After Blower Wheel Replacement - GE Dryer (Dryer Repair)
by PISCDryer 11/8/2023 7:10:25 AM(UTC)
GE Dryer Not Heating - Model: GFDS140ED0WW (Dryer Repair)
by laflair13 3/1/2023 3:14:27 AM(UTC)
GFD55ESSN0WW GE Dryer stays on Pause when I press start (Dryer Repair)
by Guest 6/8/2022 6:54:15 AM(UTC)
No power or panel lights to GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:03:52 PM(UTC)
No panel lights GE Dryer (Dryer Repair)
by Guest 4/1/2022 4:00:44 PM(UTC)
GE Dryer Model DWSR483EG9WW Squeaky & Loud (Dryer Repair)
by pdl2 12/23/2021 12:10:27 PM(UTC)
Gas GE dryer (Dryer Repair)
by Guest 6/20/2021 10:17:53 AM(UTC)
GE DRYER PART INTERCHANGEABLE (Dryer Repair)
by Guest 3/27/2021 12:02:09 PM(UTC)
GE dryer keeps pausing (Dryer Repair)
by ffltstn 3/23/2021 7:15:37 AM(UTC)
Will my GE Dryer still work (Dryer Repair)
by JW Appliance 1/29/2021 11:07:33 AM(UTC)
Trying to replace a GE dryer motor (Dryer Repair)
by Gigs34 9/8/2020 9:59:46 AM(UTC)
