nahahn
#1 Posted : 15 years ago
nahahn
The time it takes to dry clothes has almost doubled. Happened suddenly. I metered all thermostats and they seem to be working but I don't know if they are operating at the right temperature. Any ideas? I plan on replacing the operating thermostat and the high limit thermostat.
Thanks.
#2 Posted : 15 years ago
Most common causes are:
Dirty vent system
Vent louvers not opening fully
Dirty or loose blower wheel.
You can check the vent system by:
Undo the dryer from the exhaust
Run a load
If the load dries correctly then you have a vent problem.
Clean/check the vent system. Make sure the outside louvers open fully.
If you do not want lint in the house.
Take a pair of pantyhose, put one leg into the other and attach this to the dryer exhaust.
Leave enough room behind the dryer so it can blow out like a windsock.
Run a load.
Both the above will allow you to check the air flow and temp.
Also the above is NOT recommended for a gas dryer due to possible carbon monoxide problems
Dryer taking too long to dry (Dryer Repair)
by dagil 8 years ago
by Safetyguy 8 years ago
Electric Dryer taking too long to dry (Dryer Repair)
by chickenfarmer 14 years ago
by Rockets33 14 years ago
by rdpankratz 15 years ago
Gas Dryer taking too long to dry clothes (Dryer Repair)
by atucker2 15 years ago
GE Spacemaker dryer taking too long to dry (Dryer Repair)
by Chaganb 15 years ago
Amana dryer taking too long to dry clothes (Dryer Repair)
by toddsabo 16 years ago
by Christine Sullivan 16 years ago
by lorrainemc 17 years ago
