Broiler will not turn off unless unplugged.
are you saying upper broil element in oven stays on at all times, even when oven is turned off? if so sounds like electronic clock
If range is plugged in the upper broiler element will go on even without being turned on. However, if I unplug connection to upper element (in back of range) the oven will work (lower element) when bake is turned on and the stove burners will work. Is there a way to reset relay or do I need control board. What does electronic clock have to do with broiler, does it also contain relay for the broiler? Thanks.
sounds like broil relay contact on board is remaing closed at all times .replace clock/ board
