RGunner
#1 Posted : Wednesday, May 7, 2008 1:50:30 PM(UTC)
RGunner
Broiler will not turn off unless unplugged.
misterfixall
#2 Posted : Wednesday, May 7, 2008 7:28:19 PM(UTC)
misterfixall
are you saying upper broil element in oven stays on at all times, even when oven is turned off? if so sounds like electronic clock
RGunner
#3 Posted : Wednesday, May 7, 2008 9:41:16 PM(UTC)
RGunner
If range is plugged in the upper broiler element will go on even without being turned on. However, if I unplug connection to upper element (in back of range) the oven will work (lower element) when bake is turned on and the stove burners will work. Is there a way to reset relay or do I need control board. What does electronic clock have to do with broiler, does it also contain relay for the broiler? Thanks.
misterfixall
#4 Posted : Thursday, May 8, 2008 6:38:47 AM(UTC)
misterfixall
sounds like broil relay contact on board is remaing closed at all times .replace clock/ board
GE Gas Range Broiler will not shut off (Oven Repair (including Ranges and Cooktops))
by korybw 8/14/2009 8:21:55 AM(UTC)
Maytag oven - broiler will not shut off (Oven Repair (including Ranges and Cooktops))
by stevenjnorris 5/19/2009 7:35:53 AM(UTC)
Broiler will not shut off-With oven off (Oven Repair (including Ranges and Cooktops))
by POTENTATE 10/29/2007 3:51:51 PM(UTC)
