The heat in the upper oven will not sustain a set temperature and keeps flunctuating. I am thinking its some sort of sensor or thermostat?? Thanks
Measure the resistance of the oven sensor (#12 in the diagram). It suppose to be about 1100 Ohms at the room temperature. If there is nothing wrong, replace the control board. - The oven sensor Part number: AP4009009
