leej
#1 Posted : Friday, April 30, 2010 8:11:47 AM(UTC)
leej
The heat in the upper oven will not sustain a set temperature and keeps flunctuating. I am thinking its some sort of sensor or thermostat?? Thanks
#2 Posted : Friday, April 30, 2010 12:18:32 PM(UTC)
Measure the resistance of the oven sensor (#12 in the diagram). It suppose to be about 1100 Ohms at the room temperature. If there is nothing wrong, replace the control board.
- The oven sensor Part number: AP4009009
Jenn air oven misbehaving (Oven Repair (including Ranges and Cooktops))
by arn09 6/18/2015 11:33:24 AM(UTC)
How to remove a Jenn Air Oven Door and possible Hinge replacement (Oven Repair (including Ranges and Cooktops))
by williefan 11/6/2014 6:52:41 PM(UTC)
Jenn Air OVEN LIGHT WILL NOT SHUT OFF (Oven Repair (including Ranges and Cooktops))
by smylist 9/28/2014 7:52:50 PM(UTC)
Jenn Air oven won't heat all the way (Oven Repair (including Ranges and Cooktops))
by dmd1 1/7/2014 2:50:52 PM(UTC)
Jenn Air oven keep warm setting overheats (Oven Repair (including Ranges and Cooktops))
by scottmt 12/23/2013 1:36:40 PM(UTC)
jenn air oven (Oven Repair (including Ranges and Cooktops))
by jcvencill 1/21/2013 12:28:17 PM(UTC)
Jenn Air Oven not heating and light comes on by itself (Oven Repair (including Ranges and Cooktops))
by tdjohnson740 3/29/2012 11:57:07 AM(UTC)
Jenn air oven light won't turn off (Oven Repair (including Ranges and Cooktops))
by janna bestul 3/2/2012 12:29:25 PM(UTC)
Jenn Air oven door does not close all the way (Oven Repair (including Ranges and Cooktops))
by Meyekal 10/4/2011 8:49:54 AM(UTC)
Jenn Air oven fan noise (Oven Repair (including Ranges and Cooktops))
by IreneSN99 1/19/2011 10:41:37 AM(UTC)
Problem with Jenn Air oven (Oven Repair (including Ranges and Cooktops))
by johncher 1/17/2011 12:08:39 PM(UTC)
Jenn Air Oven Display and Controls Broken (Oven Repair (including Ranges and Cooktops))
by nittanykid 12/6/2010 4:32:42 PM(UTC)
Jenn air oven problems (Oven Repair (including Ranges and Cooktops))
by patrickC 8/17/2010 1:20:12 PM(UTC)
1970's Jenn Air Oven - Model Id (Oven Repair (including Ranges and Cooktops))
by dug320 8/7/2010 1:32:26 PM(UTC)
Jenn air oven no display but works (Oven Repair (including Ranges and Cooktops))
by Gary E 3/30/2010 9:23:50 AM(UTC)
