philkoan
#1 Posted : Tuesday, May 6, 2008 11:32:33 PM(UTC)
philkoan
When I set the temp control to 3-6, everything in the freezer melted. It's running normally if I set the temp control to 7-9. I think the temp control is bad (part #WR9X599). Can I replace it myself? Thank.
#2 Posted : Wednesday, May 7, 2008 2:49:26 AM(UTC)
Sure seems like a bad cold control, just make sure you get the original factory part.
philkoan
#3 Posted : Wednesday, May 7, 2008 6:25:32 AM(UTC)
philkoan
Thanks Rickappy. Can I replace it with a new one myself?
#4 Posted : Wednesday, May 7, 2008 12:49:49 PM(UTC)
No problem just make SURE you get the correct factory part and rout the capillary the same as the old one.
