When I set the temp control to 3-6, everything in the freezer melted. It's running normally if I set the temp control to 7-9. I think the temp control is bad (part #WR9X599). Can I replace it myself? Thank.
Sure seems like a bad cold control, just make sure you get the original factory part.
Thanks Rickappy. Can I replace it with a new one myself?
No problem just make SURE you get the correct factory part and rout the capillary the same as the old one.
