I installed an older dishwasher display model - but never used. Ran through normal cycle ok but won't drain. Took front lower panel off & I'm looking at what I think might be a transformer/solenoid (small motor w/pump?)to control drainage. How can I troubleshoot this? Any diagrams or schematics available? Appreciate any help or guidance.
Originally Posted by: walknite  I installed an older dishwasher display model - but never used. Ran through normal cycle ok but won't drain. Took front lower panel off & I'm looking at what I think might be a transformer/solenoid (small motor w/pump?)to control drainage. How can I troubleshoot this? Any diagrams or schematics available? Appreciate any help or guidance. Have you tried the end cycle drain test?
Originally Posted by: dfuller  Have you tried the end cycle drain test? could you explain please? (if other than advancing cycle process @ control panel)
What is the cycle drain test? Mine won't drain either? Any suggestions?
Did you get your dishwasher fixed because mine is doing the same thing?? What did you do?? Thanks,
