bradley1
#1 Posted : Monday, May 5, 2008 12:25:41 PM(UTC)
bradley1
Our oven does not heat when we put it on bake mode. The broiler and cleaning cycle work fine but when we go topreheat the oven, it stays at 100 on the control panel and every now and then you hear a clicking sound. It is a maytag precision 500 electric.
#2 Posted : Monday, May 5, 2008 5:28:14 PM(UTC)
In order to provide most accurate advise we need the complete model number of the range.
bradley1
#3 Posted : Tuesday, May 6, 2008 5:03:06 AM(UTC)
bradley1
I believe the model is MERs751baw.
#4 Posted : Tuesday, May 6, 2008 1:22:31 PM(UTC)
Remove the Bake heating element as far as the wires go and check for a burned wires.
Remove one of the wires and check the heating element for continuity.
Replace the Bake heating element if it's open.
If there is nothing wrong then replace the control board.
- The part number for the Bake heating element is AP3856342
- The part number for the control board is AP3760738
Oven does not heat to temperature set (Oven Repair (including Ranges and Cooktops))
by lauract 11/13/2015 12:53:01 PM(UTC)
Oven does not heat up (Oven Repair (including Ranges and Cooktops))
by drpflyers 7/21/2015 1:32:17 PM(UTC)
Oven does not heat past 270 (Oven Repair (including Ranges and Cooktops))
by frostyj50 11/18/2013 6:59:17 PM(UTC)
oven does not heat but stove works control panel works (Oven Repair (including Ranges and Cooktops))
by asfimag 11/10/2012 7:02:45 AM(UTC)
GE True Temp Electric Oven does not heat (Oven Repair (including Ranges and Cooktops))
by ksdavis1121 10/4/2012 11:43:04 AM(UTC)
Frigidaire oven does not heat (Oven Repair (including Ranges and Cooktops))
by camliv 9/30/2012 6:40:11 PM(UTC)
by camliv 9/30/2012 6:35:43 PM(UTC)
by escobedo55 3/11/2012 5:08:15 PM(UTC)
Oven does not heat / elements not working (Oven Repair (including Ranges and Cooktops))
by Steve Dyr59 3/8/2012 3:20:24 AM(UTC)
by davepechkis 12/6/2011 6:50:08 PM(UTC)
by fred08 9/2/2011 3:10:27 AM(UTC)
by smedleybr 7/14/2011 12:01:02 PM(UTC)
by tunnelwise 6/14/2011 12:41:11 PM(UTC)
oven does not heat to correct temp (Oven Repair (including Ranges and Cooktops))
by wawpooh 3/8/2011 11:54:18 AM(UTC)
oven does not heat up (Oven Repair (including Ranges and Cooktops))
by candyburch 2/4/2011 2:33:48 PM(UTC)
