gandpace
#1 Posted : Wednesday, April 28, 2010 6:03:57 AM(UTC)
gandpace
I just replaced the heating element and the timer switch on my maytag dreyer. The heating element appears to be heating , however the timer does not advance, and the clothes do not dry. The dreyer seems to be drying on a delicate setting , however it is set on normal dry.
Thank you
Gary
#2 Posted : Wednesday, April 28, 2010 6:35:15 AM(UTC)
A model number may help others help you.
Also does the timer not advance in both timed and auto modes?
Try different settings to see what works and what does not.
Frigidaire timer switch (Washer Repair)
by rynorfc 5/1/2021 7:10:47 PM(UTC)
Kenmore Washer Timer Switch (Washer Repair)
by Bruce Cooke 1/5/2021 10:19:52 AM(UTC)
Need to sweep timer switch to start dryer (Dryer Repair)
by jebstep 1/4/2019 8:17:56 PM(UTC)
Timer Switch works on agitate but does nothing when that cycle is done (Washer Repair)
by Creeker721 7/4/2016 11:39:16 AM(UTC)
timer switch wiring diagram (Dryer Repair)
by nathaniel65 4/10/2015 9:40:41 AM(UTC)
Replacing Timer Switch-uh oh-Wrong timer sent? (Dryer Repair)
by travisp83 3/16/2015 1:06:43 PM(UTC)
Timer Switch? (Washer Repair)
by polkarandy 1/6/2014 5:55:42 PM(UTC)
New door lock and timer switch (Washer Repair)
by Capebouy 11/16/2013 4:24:39 PM(UTC)
Matching wires on a timer switch (Dryer Repair)
by whiley23 2/22/2013 11:56:55 AM(UTC)
Estate Electric Dryer won't start - Checking continuity on Timer switch? (Dryer Repair)
by scottietj 7/26/2012 11:10:56 AM(UTC)
Is it the timer switch? (Dryer Repair)
by Craig007 3/11/2012 6:17:37 PM(UTC)
What causes the defrost timer switch to go bad? (Refrigerator & Freezer Repair)
by Travis Katzer 10/20/2011 9:57:40 AM(UTC)
timer switch buzzing (Washer Repair)
by midnight1 6/24/2011 8:29:25 AM(UTC)
Replaced Timer Switch (Dishwasher Repair)
by Handyman3 1/10/2011 6:24:22 AM(UTC)
GE Dryer Timer Switch Broke and No Heat (Dryer Repair)
by doughboy52 10/17/2010 3:44:32 PM(UTC)
