207 Pages«<7879808182>»
#791 Posted : Tuesday, April 13, 2010 12:50:42 PM(UTC)
Originally Posted by: TJ17 Go to Quoted Post
Hi Gene,
Been in circles with our GE Profile freezer bottom the last month or so... About 6 weeks ago our fridge got warm, freezer was fine. Repair guy switched out the main board / 24 hr defrost and it worked for fine for a month. Then we had the same problem. This time he says the main board is fine but, can't find the problem. Cool air comes through to the fridge only when the freezer is open. We've cleared all food so nothing is blocking... Any ideas?
THANK YOU!:confused:
Possible the air return from the fresh food compartment into the freezer is blocked.
goodshink
#792 Posted : Tuesday, April 13, 2010 2:59:44 PM(UTC)
goodshink
Gene, Thank you for your reply. The model # is GSH22JFTA CC. Like I said I replaced the main control board as well as the upper thermistor. I jumped the heater wire on the board and the heater glows red. I suppose this means the thermostat as well as the heater is functioning correctly. The only thing I didn't replace was the lower thermistor. Could this be the problem? The upper thermistor did have some black on the tip. Thank you for your quick reply.
#793 Posted : Tuesday, April 13, 2010 3:30:50 PM(UTC)
Does the evaporator fan (inside the freezer) work properly?
Here are the breakdown diagrams and Replacement parts for General Electric GSH22JFTACC Refrigerator | AppliancePartsPros.com
goodshink
#794 Posted : Tuesday, April 13, 2010 3:37:41 PM(UTC)
goodshink
Gene, Yes it does!
#795 Posted : Tuesday, April 13, 2010 3:44:13 PM(UTC)
Sounds really strange. Replace the second thermistor and, if it would not solve the problem, then probably one of new parts is defective.
Do0d
#796 Posted : Thursday, April 15, 2010 11:52:15 PM(UTC)
Do0d
Hello Gene,
Perhaps you can get me sorted. I have a non-working GE GSL22JFPH BS, neither the fridge nor the freezer seem to be cooling. I ordered an new motherboard, although the fridge seems to be running, although the compressor does seem quiet (perhaps it's just that way on this model?) I installed the new mobo part #AP4436216, but the unit is still not cooling down. Any idea what other problems I should turn my attention to? Any assistance would be appreciated greatly.
TIA
Do0d
#797 Posted : Friday, April 16, 2010 3:57:33 PM(UTC)
It is very important to figure out if the compressor is running. Touch the compressor to see if it's vibrating. Also can you see the fans inside the freezer and on the back of the refrigerator running?
Here are the breakdown diagrams and Replacement parts for General Electric GSL22JFPHBS Refrigerator | AppliancePartsPros.com
Do0d
#798 Posted : Friday, April 16, 2010 4:44:08 PM(UTC)
Do0d
I can feel the compressor running & it feels cold to the touch. Where should I be looking fopr the fans? I checked inside the back wall of fridge & freezer and felt some slight air movement, or should I be looking at the fan at the bottom rear of the unit, below the motherboard access area?
#799 Posted : Friday, April 16, 2010 4:52:10 PM(UTC)
If the compressor is running but it is cold on touch, then there is a problem with the sealed (cooling) system. It has to be diagnosed by a pro. You have to call GE to find out if it's still under the warranty.
Do0d
#800 Posted : Friday, April 16, 2010 5:21:25 PM(UTC)
Do0d
Thanks Gene,
I havve a guy coming out tomorrow to check it out further. I appreciate all the help. This forum is fantastic, seeing how many people got their appliances working again is very inspiring to the do-it-yourselfer!
Thanks again!
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
