Debi1220
#1 Posted : Friday, April 16, 2010 11:30:58 AM(UTC)
Debi1220
My father's GE PSS26MGTAWW Ice Dispenser quit working recently afer he pressed the ice lever for a looooooong time with no ice coming out. Now, the ice dispenser makes no noise at all when you press the ice lever and the refrigerator motor actually stops. The water dispenser still works, but the dispenser light dims when you press the water lever. From what I have read, it seems that the main board has to be replaced. Is it possible that another part will have to be replaced also? Thank you.
magician59
#2 Posted : Friday, April 16, 2010 12:39:52 PM(UTC)
magician59
It could be anything from the dispenser switch to the auger motor itself. Some troubleshooting may have to be done after the board is replaced.
Whirlpool Ice Dispenser Auger will not run (Refrigerator & Freezer Repair)
by WhirlpoolDave 4/1/2024 12:44:26 PM(UTC)
KitchenAid KSSP42QTS00 Ice dispenser leaking (Refrigerator & Freezer Repair)
by sternern 3/20/2024 2:21:47 PM(UTC)
Door Ice dispenser not functioning properly (Refrigerator & Freezer Repair)
by abennet4@comcast.net 12/6/2023 4:45:55 PM(UTC)
Amana AFI2538AEB refrigerator ice dispenser door opens and closes continually (Refrigerator & Freezer Repair)
by Guest 9/30/2023 6:59:28 AM(UTC)
Ice dispenser light on Frigidaire FGHC2342LF3 not working (Refrigerator & Freezer Repair)
Belarus parkerfly 9/2/2023 10:27:54 AM(UTC)
Whirlpool Ice Dispenser Auger issue (Refrigerator & Freezer Repair)
by Daveh839 7/11/2023 11:36:45 AM(UTC)
how to determine if kenmore ice dispenser is bad (Oven Repair (including Ranges and Cooktops))
by Guest 7/6/2023 3:32:28 PM(UTC)
Frigidaire water/ice dispenser issue FFHS2322MSKA (Refrigerator & Freezer Repair)
by Guest 6/4/2023 10:21:19 PM(UTC)
Ice dispenser freezing (Refrigerator & Freezer Repair)
by jesus freak 1/22/2023 11:25:08 PM(UTC)
Ice Dispenser on Frigidaire side by side pulses when dispensing ice (Refrigerator & Freezer Repair)
by JordanNolan 1/8/2023 8:50:08 AM(UTC)
GE side-by-side water/ice dispenser stops working during defrost (Refrigerator & Freezer Repair)
by pvsherman 12/18/2022 11:23:17 AM(UTC)
Whirlpool Ice Dispenser loud (Refrigerator & Freezer Repair)
by jbusbee83 7/25/2022 3:46:45 PM(UTC)
Ice dispenser condensation (Refrigerator & Freezer Repair)
by Guest 6/16/2022 10:57:08 AM(UTC)
Frigidaire FRS6LF8FS1 ice dispenser not dispensing ice (Refrigerator & Freezer Repair)
by BradASchreiber 5/31/2022 10:45:28 AM(UTC)
Water/ice dispenser funnel won’t retract (Refrigerator & Freezer Repair)
by Guest 2/5/2022 1:15:16 PM(UTC)
