utep42
#1 Posted : 18 years ago
utep42
I have a Maytag Front load washer model MAH4000AWW, that been pretty dependable for 7 years. This morning my wife started a load of clothes and as I walked threw the laundry room I smelled what seemed like a electrical burning smell. The smell was coming from the washer, but it seemed to be working fine. Well after the cycles completed I opened the door and noticed the clothes were still wet. So I turned the time to the spin cycle and turned it on, unit seemed to rotate, but the spin cycle never engaged, I also noticed the door lock light was not on and I was able to open the door while in operation, the door lock didn't engage. This problem seems identical to bpcolll problem posted 8/3/07. I would like to do the repairs myself but don't want to permanently disable the wife's Neptune. I need the steps, do I replace the control board or can I just replace the resisters? Or is it the lock switch. Any help would be greatly appreciated. Should I just have a service tech come out at 69.00 to tell me it's broke! Thank you in advance.
ApplianceJunk
#2 Posted : 18 years ago
ApplianceJunk
Let me save you some money, it's broke.. :)
There, that will be one beer please, lol...
Anyway, check this out.
Repair Guide
If you find the R-11 resistor burnt up I would replace the board and forget about trying to repair it.
Cowboy5376
#3 Posted : 16 years ago
Cowboy5376
Our neptune washer has been very reliable for several years. This year it stated to leave some of our clothes wet. Especially the towels. I've located the displacement switches. Is there a way to check if switches are not fried??
neptune help
#4 Posted : 16 years ago
neptune help
I would repair it and replace the defective wax motor... What do you have to lose? Worst case you will have to replace the control board which runs $169 complete... See MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR for the repair kit and new control board.
In addition, see MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR for a funny Neptune song that explains the faulty door latch wax motor issue...
neptune help
#5 Posted : 16 years ago
neptune help
Neptuners,
Don't forget to replace your door latch wax motor... See MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT + 12002535 WAX MOTOR for a funny song that explains the faulty door latch wax motor issue. Keep in mind that if you have an earlier MAH3000, you have (3) of those darlings you should proactively replace.
#6 Posted : 16 years ago
Cowboy5376
Below assumes yours is also a MAH4000AWW
Model MAH4000AWW
Here is a service manual which should help check the switches
http://www.servicematters.com/m...ibrary/docs/16010061.pdf
Maytag Neptune washer stops and won't unlock (Washer Repair)
by dctaz37 4 years ago
Maytag Neptune Washer motor replacement (Washer Repair)
by TiffMom 6 years ago
Maytag neptune washer logic board (Washer Repair)
by Busch58 7 years ago
Maytag Neptune washer wont spin or cycle (Washer Repair)
by Tonya 44 9 years ago
Maytag Neptune Washer Clutch Replacement (Washer Repair)
by helplessm355 10 years ago
maytag neptune washer MAH9700AWM wont spin (Washer Repair)
by biztyke 10 years ago
Maytag Neptune Washer Shuts off After Water Fill (Washer Repair)
by kluskc 11 years ago
Maytag Neptune Washer will not spin (Washer Repair)
by BStevens82 12 years ago
Maytag Neptune washer code uc (Washer Repair)
by Jef_R 12 years ago
Maytag Neptune Washer shuts off (Washer Repair)
by HHB 12 years ago
Maytag Neptune Washer Spin Cycle Noise (Washer Repair)
by jayjaysin 13 years ago
maytag neptune Washer (Washer Repair)
by alfonso m 13 years ago
Maytag Neptune washer & dryer reputation (Washer Repair)
by LLLN 13 years ago
Maytag Neptune Washer - cold won't fill (Washer Repair)
by sandylouwhoo 13 years ago
