207 Pages«<7677787980>»
#771 Posted : 15 years ago
Jody,
Remove the damper (#115 on the diagram) and check the motor and switch for continuity, and mechanical parts of it. If there is nothing wrong then the problem very likely is a bad adaptive defrost control.
- The damper Part number: AP3958400
- The ADC Part number: AP3959125
hd4ou
#772 Posted : 15 years ago
hd4ou
Hey Gene, I found a guy here that had a spare dampner. Put it all together and plugged it in and the dampner motor open up then closed and cycled like this 3 or 4 time over a 5 minute period then it just stayed closeed and 3 hours later it still appears to be closed. Still think its the adaptive frost control or is there something else that is susposed to keep the dampner open??
#773 Posted : 15 years ago
If you are sure that this spare damper is good, then the problem very likely is a bad ADC. Unfortunately there are no manuals for this model.
hd4ou
#774 Posted : 15 years ago
hd4ou
well im not sure but it appears to be functional. i mean its a 120 volt motor with a micro switch on the cam that interrupts power to the motor when opened. im assuming there is some sort of control that stops rotation at some point.. both the motor and micro switch appear to be operating as they should. i must admit i am unsure what it is that makes the dampner remain open at a certain point. im certainly not disputing your suggestion.. simply just wondering how it works.. i will see if this local guy has a spare controller and let you know. im guessing its the flat square box under the housing by the dampner about 3 x 4 inchs correct? thanks again Gene...
#775 Posted : 15 years ago
According to the wiring diagram the power to the damper motor comes from the ADC, but the position of the damper gate controls by the refrigerator temperature control (thermostat). It is possible the temperature control is bad as well, but you can check it for continuity.
EVERAM
#776 Posted : 15 years ago
EVERAM
Hi! I just wanted to thank you, your info was very useful, change the fan motor, was pretty easy, everything is working fine, you are doing a great service, thank you so much. Eve
Slashz28
#777 Posted : 15 years ago
Slashz28
Awesome !!:) Thank you very much Gene. I may just buy all 3 parts and just replace them. Saves the time troubleshooting, and this way all those components are new.
Thank you very much once again!
Cheers
Tom
hd4ou
#778 Posted : 15 years ago
hd4ou
ok Gene, i got a thermostat control from Mr. Sellars and checked mine first. notta. installed his and wal lah. everything working great. thanks for the diagram. you are exactly right. thermostat controls dampner position.. this ones quite a bit more complicated than my whirlpool dampner system...thanks again...Jody
#779 Posted : 15 years ago
You are welcome Eve. I'm glad you were able to fix it.
#780 Posted : 15 years ago
You are welcome Tom.
Most likely all three new parts will fix it, but there is a very small chance that without the proper diagnosis there is something else wrong.
Good luck,
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 12 years ago
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 15 years ago
by allemich 16 years ago
