Jim Wheeler
#1 Posted : Wednesday, April 7, 2010 10:55:06 AM(UTC)
Jim Wheeler
I have a roper RAS7133KQO washing machine. The machine turns on the wash cycle, fills with water, agitates through the wash cycle and stops. The wash water does not pump out, the spin cycle does not turn, and the rinse cycle does not start. I have tried adjusting the knobs manually, that did not work. I put it on the rinse cycle, nothing happens. When it stops the moter does not spin so it doesn't appear to be the belt and I checked that vissually. HELP
#2 Posted : Wednesday, April 7, 2010 3:38:35 PM(UTC)
Most likely the problem is a bad lid switch (#11 on the diagram). You have to remove the washer cabinet to replace it.
- The lid switch Part number: AP3100003
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL RAS7133KQ0 | AppliancePartsPros.com
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 6 time(s).
Whirlpool stops after wash cycle will not drain or spin (Washer Repair)
by JF2015 1/4/2015 7:19:52 AM(UTC)
Whirlpool washer stops after wash cycle (Washer Repair)
by u71589 6/21/2013 1:42:56 PM(UTC)
maytag neptune stops after wash cycle (Washer Repair)
by willy t 5/20/2012 10:32:05 AM(UTC)
by jrevino 2/26/2010 12:15:01 PM(UTC)
Washer stops after wash cycle (Washer Repair)
by stanwill 11/28/2009 10:13:53 AM(UTC)
Timer stops after wash cycle (Washer Repair)
by YODAUSA 5/11/2008 8:07:06 AM(UTC)
by john miller 12/26/2007 8:22:22 PM(UTC)
