corobitgf
#1 Posted : Tuesday, April 6, 2010 7:54:58 PM(UTC)
corobitgf
The moderl number is LEN2000PW1 an electric dryer, I bought it 6 years ago, it started two days ago to dry for an extended amount of time, and today it stoped heating? I thought about the box heater, element heater and even the thermostat. Does anyone know or have any idea? I just dont want to go over and spend 400 to 500 on a new one, and problably find out it could have been something less expensive.
Cindy:confused:
magician59
#2 Posted : Wednesday, April 7, 2010 9:11:44 AM(UTC)
magician59
Your description of the symptoms leads to a clogged or restricted ventilation system. Check to make sure the vent is clear, from the dryer, all the way to the outside of the house. Next, tell us whether the motor still runs without heat; or you get nothing at all when you try to start it.
Samsung dryer wont heat (Dryer Repair)
by Dabenthall 12/19/2016 10:51:29 AM(UTC)
my whirpool duet dryer wont heat (Dryer Repair)
by bluelake78 12/18/2016 7:01:30 PM(UTC)
by bennieman 11/9/2016 10:30:17 AM(UTC)
by mkrason 12/18/2015 3:28:25 PM(UTC)
Maytag Dryer wont heat (Dryer Repair)
by Rescal 8/18/2015 5:23:15 PM(UTC)
by highcountry71 8/16/2015 8:42:56 AM(UTC)
Kenmore 80 Series...Dryer Wont Heat... Tested/continuity good (Dryer Repair)
by xtacbyme 6/3/2015 7:57:15 PM(UTC)
dryer wont heat in timed dry mode (Dryer Repair)
by thildy 5/7/2015 2:26:44 PM(UTC)
by Jim Winkels 4/5/2015 5:08:25 PM(UTC)
Whirlpool dryer wont heat (Dryer Repair)
by ekujustice 4/2/2015 4:47:16 PM(UTC)
Dryer wont heat on timed dry and works sometimes on auto setting (Dryer Repair)
by AJM57 3/14/2015 8:45:13 AM(UTC)
by Nmiles 11/24/2014 2:22:06 PM(UTC)
electric dryer wont heat (Dryer Repair)
by janietodd 9/24/2014 11:10:25 AM(UTC)
ge dryer wont heat (Dryer Repair)
by appliancerepairguy 9/13/2014 11:31:54 PM(UTC)
Dryer wont heat - element and fuses/limiters fine (Dryer Repair)
by watsonwabbit69 6/19/2014 10:41:14 AM(UTC)
