element will not heat. element and thermastats, and fuse are good. the dryer runs but doesnt heat and has 220 v at plug
how did u check element and t stat did u check for resistance on element also check for 220 at terminal block
Originally Posted by: manduxe  how did u check element and t stat did u check for resistance on element also check for 220 at terminal block checked ohms all tested and had 1.5-1 ohms has 110volts to all the thermastats, fuses, and element, and coming out of them, but will not heatup
what was the ohms on element if its 1.5-1 it does not look right should be around 13 ohms also heating element needs 240 volts to operate
