sloefoot25
#1 Posted : Monday, March 29, 2010 12:23:49 PM(UTC)
sloefoot25
element will not heat. element and thermastats, and fuse are good. the dryer runs but doesnt heat and has 220 v at plug
manduxe
#2 Posted : Tuesday, March 30, 2010 9:29:19 PM(UTC)
manduxe
how did u check element and t stat did u check for resistance on element also check for 220 at terminal block
sloefoot25
#3 Posted : Saturday, April 3, 2010 6:36:26 AM(UTC)
sloefoot25
checked ohms all tested and had 1.5-1 ohms has 110volts to all the thermastats, fuses, and element, and coming out of them, but will not heatup
manduxe
#4 Posted : Saturday, April 3, 2010 9:28:35 AM(UTC)
manduxe
what was the ohms on element if its 1.5-1 it does not look right should be around 13 ohms also heating element needs 240 volts to operate
side of dryer getting extreamly hot (Dryer Repair)
by clstewa0 12/26/2023 4:24:13 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
GE GFDS355GLDMS Gas Dryer Getting tired...Recommendation for Tune-up? (Dryer Repair)
by jim.starzynski@gmail.com 4/4/2020 8:17:16 AM(UTC)
Dryer getting red hot while drying (Dryer Repair)
by goosemasterkl 8/26/2019 7:43:24 AM(UTC)
Dryer gets hot on top and back (Dryer Repair)
by Morgan5 3/19/2018 12:28:34 PM(UTC)
Dryer gets hot, but takes 2-3 cycles to dry (Dryer Repair)
by JDT73 10/27/2017 6:41:15 PM(UTC)
Dryer gets hot and trips breaker (Dryer Repair)
by BKHOMES 11/20/2014 11:18:57 AM(UTC)
GE Dryer gets too hot (Dryer Repair)
by Bud_Jones 10/8/2014 9:41:09 AM(UTC)
Whirlpool Dryer gets hot blows thermal fuse (Dryer Repair)
by JanOlson 7/6/2014 12:27:59 PM(UTC)
replaced faulty heating element, now dryer gets too hot. Help please! (Dryer Repair)
by sheriowaso 11/15/2013 4:21:37 PM(UTC)
Kenmore Elite Dryer Getting To Hot (Dryer Repair)
by TINAO 4/10/2013 10:06:52 AM(UTC)
dryer get's hot but won't turn (Dryer Repair)
by jeeppo 2/24/2013 12:34:26 PM(UTC)
Whirlpool Dryer GEW9878LWO doesn't stay running (Dryer Repair)
by jorkvilleyoe 2/3/2013 10:00:56 AM(UTC)
Dryer gets clothes too hot even on delicate (Dryer Repair)
by BrianH69 11/26/2012 6:03:52 AM(UTC)
Gas Dryer getting hot but won't dry troubleshooting (Dryer Repair)
by sosoguju 8/29/2012 12:19:23 PM(UTC)
