BruceMcCoy
#1 Posted : Wednesday, April 23, 2008 11:33:05 AM(UTC)
BruceMcCoy
I have an old Whirlpool that fills with water, then immediately drains, not simultaneously and before it enters into an agitate cycle. I have checked the timer and the wig-wag and both read OK on the ohm-meter. The plungers appear to be operating correctly (they aren't broken and are loose when not energized) and the cams don't look bent. Is there a way that the plungers wouldn't work even when the wig-wag is checking OK?
misterfixall
#2 Posted : Wednesday, April 23, 2008 1:10:09 PM(UTC)
misterfixall
i feel problem is the pump drain port remaining open in wash
BruceMcCoy
#3 Posted : Wednesday, April 23, 2008 1:26:48 PM(UTC)
BruceMcCoy
Thanks- I'll check it tonight. Would this prevent the machine from going into the agitate cycle?
misterfixall
#4 Posted : Wednesday, April 23, 2008 2:29:54 PM(UTC)
misterfixall
yes, if the set water level is not reached .
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
