smodellb
#1 Posted : 15 years ago
smodellb
Removed cover from Evaporator and was frozen solid. Defrosted and is working fine. How would I check the Mother Board to see if the defrost cycle is working.
FridgeDoctor
#2 Posted : 15 years ago
FridgeDoctor
Groups: Expert
checking the board is too complicated without proper training, even in here.
Instead test continuity through your defrost heater element, you can remove it from the system to test it. the other part to test is the defrost be-metal thermostat, this part needs to be continuity tested while it is clipped to the freezing cold evaporator, otherwise you will get a false open circuit reading.
If both of these parts test ok, you p[robably have a bad mother board.
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 8 years ago
Defrost not working (Refrigerator & Freezer Repair)
by wagnerlip 8 years ago
by smokyjoeko 10 years ago
defrost not working (Refrigerator & Freezer Repair)
by carlosl. 12 years ago
GSS201EMDWW Defrost not working, again. (Refrigerator & Freezer Repair)
by Davdc5 13 years ago
by swallman 13 years ago
Adaptive Defrost not working (Refrigerator & Freezer Repair)
by radair 14 years ago
Kitchenaid refrig: defrost not working leading to icy refrigerator (Refrigerator & Freezer Repair)
by osbock 14 years ago
GE refrig defrost not working (Refrigerator & Freezer Repair)
by beachval 15 years ago
Defrost not working? (Refrigerator & Freezer Repair)
by jfuqua1966 15 years ago
by red arrow 57 15 years ago
Samsung Refrigerator Defrost Not Working (Refrigerator & Freezer Repair)
by eckerj 16 years ago
Defrost Not Working Properly (Refrigerator & Freezer Repair)
by machengo82 16 years ago
Auto defrost not working (Refrigerator & Freezer Repair)
by kimseyray 16 years ago
Defrost not working after all new parts (Refrigerator & Freezer Repair)
by tradencookies 16 years ago
