JoeNIndy
#1 Posted : Monday, March 22, 2010 3:20:51 PM(UTC)
JoeNIndy
The only time timer gives me power is on the cool-down cycle of the perm press cycle, with the one switch to yes! Checked continuity of all sensors and safty as well as resistance of heating coils, all good! My guess is timer or motor switch. I cleaned out all the lent thought it was an over temp switch but doesn't seem to be.
I'd be grateful for any help, it my Step-Mom's and she needs dry clothes for her 90'th Birthday the 27th of this month!.
Thanks!
#2 Posted : Monday, March 22, 2010 4:39:52 PM(UTC)
I'm afraid I did not get it clear:
Quote:
...with the one switch to yes!...
JoeNIndy
#3 Posted : Monday, March 22, 2010 5:19:22 PM(UTC)
JoeNIndy
It's the Press Guard Switch turned to yes.
#4 Posted : Monday, March 22, 2010 7:34:46 PM(UTC)
Very likely the problem is a bad timer, but I can not say I'm positive about it because I do not have the wiring diagram for this model.
- The timer Part number: AP2042833
P.S. Have you checked the resistor (#148 on the diagram)?
JoeNIndy
#5 Posted : Tuesday, March 23, 2010 5:53:00 AM(UTC)
JoeNIndy
Yes, I believe it was 3.7k Ohms. When I checked the Resistor it was still in the circuit as were the sensors, limits and safety when checked for continuity . Is there a way to check the timer switch on or off the machine? Thanks,
Joe
JoeNIndy
#6 Posted : Tuesday, March 23, 2010 6:22:40 AM(UTC)
JoeNIndy
Here are scans of the diagrams that were in the dryer.
File Attachment(s):
SCAN Hotpoint dryer sheet no 78001.pdf (141kb) downloaded 4 time(s).
SCAN Hotpoint dryer sheet no 78002.pdf (125kb) downloaded 4 time(s).
