waltcnk
#1 Posted : Wednesday, March 17, 2010 3:18:30 PM(UTC)
waltcnk
Works fine on all other cycles, but on spin cycle it makes a loud rythemic klack, klack, klack as it starts spinning. As it gets up to speed when it is lighter with less water, the sound diminishes but is still there. This just started yesterday....Chet
#2 Posted : Wednesday, March 17, 2010 5:58:33 PM(UTC)
Most likely the problem is a bad clutch (#5 on the diagram).
You have to drop off the transmission in order to replace it.
Here is the Service manual.
- The clutch assembly Part number: AP3094537
waltcnk
#3 Posted : Thursday, March 18, 2010 12:20:21 PM(UTC)
waltcnk
Thanks Gene,
I appreciate the help. I am working on it now.
Chet.
waltcnk
#4 Posted : Thursday, March 18, 2010 2:42:34 PM(UTC)
waltcnk
Originally Posted by: waltcnk Go to Quoted Post
Thanks Gene,
Chet.
Gene, I found the plastic "brake cam driver" has a broken pin which aligns it with the "brake release cam". Do you think that is what was causing all the klacking?
Chet
#5 Posted : Thursday, March 18, 2010 5:05:43 PM(UTC)
Yes, you got it!
whirlpool washer will only agitate on gentle (Washer Repair)
by marycwells@gmail.com 5/8/2024 7:09:34 PM(UTC)
Whirlpool washer noise for new washer (yes under warranty) (Washer Repair)
by Huntersdl 4/30/2024 3:01:43 PM(UTC)
whirlpool washer model WFW6620HW2 Fried? (Washer Repair)
by justme56 2/11/2024 8:42:17 AM(UTC)
Whirlpool washer F20 code (Washer Repair)
by wstrick14 1/6/2024 3:42:34 PM(UTC)
Whirlpool washer clicking when filling (Washer Repair)
by RogeM 12/3/2023 8:13:49 AM(UTC)
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Noise and wobble during spin cycle in top load Whirlpool washer (Washer Repair)
by Guest 8/19/2023 5:31:59 AM(UTC)
Whirlpool washer Not spinning 6/21/23 (Washer Repair)
by yveron 6/21/2023 11:33:50 AM(UTC)
whirlpool washer buzzer Way too loud! (Washer Repair)
by Guest 5/1/2023 11:33:43 AM(UTC)
whirlpool washer wt5057lo powers on but won't start (Washer Repair)
by Guest 4/20/2023 4:19:14 PM(UTC)
Whirlpool washer spins during drain cycle (Washer Repair)
by jsdscot 1/23/2023 5:04:07 PM(UTC)
Whirlpool Washer WTW5105HW1- Loud Spin Cycle- Spring/suspension question (Washer Repair)
by gabeTBP 1/21/2023 6:26:31 AM(UTC)
No Hot Water in Whirlpool Washer (Washer Repair)
by Billpa2023 1/4/2023 12:12:44 PM(UTC)
whirlpool washer fill and drain only (Washer Repair)
by Randero 10/14/2022 2:53:13 AM(UTC)
Capacitor for Front Load Whirlpool washer Model # wfw9550ww00 (Washer Repair)
by Guest 9/11/2022 2:49:05 PM(UTC)
