Works fine on all other cycles, but on spin cycle it makes a loud rythemic klack, klack, klack as it starts spinning. As it gets up to speed when it is lighter with less water, the sound diminishes but is still there. This just started yesterday....Chet
Thanks Gene, I appreciate the help. I am working on it now.
Chet.
Originally Posted by: waltcnk  Thanks Gene, I appreciate the help. I am working on it now.
Chet. Gene, I found the plastic "brake cam driver" has a broken pin which aligns it with the "brake release cam". Do you think that is what was causing all the klacking? Chet
