rmccarthy
#1 Posted : 17 years ago
rmccarthy
My ice maker has stopped working.The tray had no water in it,I removed the ice maker from the freezer ,didnt see any obvious problems.I reinstalled it and checked it about 3 hrs later,but it did not fill with water .Checked it the next day and the tray did have ice in it but did not release it .(the ice is still in tray for about 7 hrs now).The Infrared lite seems to be working fine(blinks with flapper open ,then stays on with flapper closed).Any Ideas? Thanks Ray
fixtec90
#2 Posted : 17 years ago
fixtec90
access remitter board (right-side of freezer) lossen harness enough to jump the two center wires (black and black-grey I believe). Use a screw driver to complete that curcuit. Your icemaker should start to cycle. If no, replace i/m. If yes, replace board.
rmccarthy
#3 Posted: : 17 years ago
rmccarthy
OK From top to bottom on the harness plug I had white,yellow,black with white stripe,black,brown with white stripe,orange with black stripe. I jumped the black to black with white stripe. Nothing happened. The fact that there is no water in the tray(tray hasnt filled with water from begining of problem) would still be a result of a bad I/M???? Thanks Ray
rmccarthy
#4 Posted : 17 years ago
rmccarthy
PS I also noticed that some times when I open freezer door the infra red light does not go on at all ????????
fixtec90
#5 Posted : 17 years ago
fixtec90
Jumping black to black/white was correct. That should have cycled the icemaker for as long as you left it jumped. If your gears didn't start turning I/M is no good. I can't say if the other things mentioned are an addition issue, but I can say while jumped your I/M should cycle.
fixtec90
#6 Posted : 17 years ago
fixtec90
Yes no water in the tray can be a bad I/M. When voltage is supplied to the I/M it first heats to harvest ice in tray. It will not send power to the valve until the gears have turned enough to tell the I/M the tray is empty.
Bad gears=no power to fill valve.
rmccarthy
#7 Posted : 17 years ago
rmccarthy
Thanks for your help. I will order the new ice maker, Do I need the whole IM or just the module?Would you happen to know the part # I need for this model(GS6SHEXNS00) ? Thanks again for your help,I will let you know the results.
GE Fridge GFE28GMKJES Ice Maker Not Working (Refrigerator & Freezer Repair)
by aopenshaw about a year ago
Ice Maker Not Working Properly - Running Out Of Ideas (Refrigerator & Freezer Repair)
by barlav 3 years ago
Sub-zero ice maker not working - water line? (Refrigerator & Freezer Repair)
by doingthebestican 4 years ago
Samsung RF267 fridge ice maker not working (Refrigerator & Freezer Repair)
by splumer 4 years ago
Ice maker not working, can I get into service mode (Refrigerator & Freezer Repair)
by Mickeddie 4 years ago
GE freezer ice maker not working (Refrigerator & Freezer Repair)
by Asmodaues 4 years ago
GE Mother Board Replacement - Ice Maker Not Working (Refrigerator & Freezer Repair)
by oneijack 5 years ago
Maytag WRX735SDHZ00 Ice Maker not working (Refrigerator & Freezer Repair)
by mp1975 5 years ago
Kenmore 795.76203.901 refrigerator/freezer ice maker not working (Refrigerator & Freezer Repair)
by pauldw 5 years ago
GE Artica ice maker not working (Refrigerator & Freezer Repair)
by gr8filed 6 years ago
Ice Maker Not Working - Help with Diagnosis (Refrigerator & Freezer Repair)
by kenbo22 7 years ago
Ice maker not working (Refrigerator & Freezer Repair)
by Stuckbad 8 years ago
Ice Maker not working after replacing several parts (Refrigerator & Freezer Repair)
by Rylos 8 years ago
frigidaire ffss2614qs0 ice maker not working but dispenses water (Refrigerator & Freezer Repair)
by whstrain 8 years ago
Kitchen Aid ice maker not working (Refrigerator & Freezer Repair)
by Rockk 8 years ago
