Update bailed out water tried again to go from rinse to spin timer knob makes clicking sound watched motor tries to engage, is it the knob?
Originally Posted by: MDhoff  Update bailed out water tried again to go from rinse to spin timer knob makes clicking sound watched motor tries to engage, is it the knob? Remove the belt and check how freely the pump pulley and the transmission pulley are moving in both directions. Post the results. Here are the breakdown diagrams and Replacement parts for MAYTAG MAV8600AWW Washer, Atlantis | AppliancePartsPros.comGene.
Transmission pulley moves freely both directions Pump pulley only freely to right not at all to the left
Originally Posted by: MDhoff  ...Pump pulley only freely to right not at all to the left... The pump is the culprit. No doubt about it. - The pump Part number: AP4373022
Thanks Gene your great Hopefully not to much effort to put in for a gal
So easy, all is working well
I'm glad you are back in business. Thank you for the feed back.
no clothes unbalnced Model Number: MAV8600AWW Brand: Maytag Age: 5 - 10 years How to fix and what to look for?
