bej13
#1 Posted : Monday, March 15, 2010 6:52:26 AM(UTC)
bej13
The dishwasher runs ok and counts down to 44 min. and continues to run but min. stay at 44. After a few min. you can open the door and restart. But sometimes you have to try and restart 3 or 4 times before it will continue count down, ? Thanks for any help you can give. B.E.J.
#2 Posted : Monday, March 15, 2010 3:20:57 PM(UTC)
Perform the troubleshooting and the service diagnostics as described in the Tech sheet. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GU2455XTSQ1 Undercounter Dishwasher | AppliancePartsPros.com
bej13
#3 Posted : Monday, March 15, 2010 6:18:04 PM(UTC)
bej13
If I am doing it right the first number was 88-d3-07-05 Clean& Normal led14 then 12 B.E.J
bej13
#4 Posted : Monday, March 15, 2010 6:19:54 PM(UTC)
bej13
This is the second DW we had and the last one did the same thing after two years, never could find any one to repair it. Bej
#5 Posted : Tuesday, March 16, 2010 5:04:10 PM(UTC)
Quote:
...counts down to 44 min. and continues to run but min. stay at 44...
How long it stays at this number? It can be due to the thermal hold. The water inside the dishwasher heats up and it will be paused until the water inside would not reach a proper temperature. If the water temperature is much bellow recommended 120°F then the heating (and pause) can take pretty long time.
Measure the water temperature inside the dishwasher at the beginning of this stop and do it again after 20 minutes. Post the results.
bej13
#6 Posted : Saturday, March 20, 2010 7:47:12 PM(UTC)
bej13
When It stopped at 44 Min I opened it and the water temp was 129 deg.
I closed the door and and it stayed at44 for 16 min. then started down. The water was 134 at that time. It completed the cycle then. We only run it about every three days. The cycle started at 79 min.
#7 Posted : Sunday, March 21, 2010 12:10:02 AM(UTC)
Looks like it works as designed.
Whirlpool Gold Dishwasher not running cycles properly (Dishwasher Repair)
by Joe513 6/20/2022 12:49:46 PM(UTC)
Whirlpool Gold Dishwasher stops Mid-Cycle (Dryer Repair)
by DOCallah 1/2/2015 7:53:56 AM(UTC)
Whirlpool Gold Dishwasher makes sounds like popcorn or broken glass? (Dishwasher Repair)
by Stacey W 6/20/2014 12:36:51 PM(UTC)
Whirlpool Gold dishwasher won't start (Dishwasher Repair)
by CharleeG 11/4/2013 6:12:51 AM(UTC)
Whirlpool Gold Dishwasher Rinse Only Light Blinks (Dishwasher Repair)
by Steeverno 7/6/2012 7:58:02 PM(UTC)
whirlpool gold dishwasher control light on (Dishwasher Repair)
by brucesheinbaum 3/9/2012 4:20:42 AM(UTC)
Whirlpool Gold Dishwasher Soap Dispenser Latch (Dishwasher Repair)
by lmcduff3 6/30/2011 8:21:17 AM(UTC)
Whirlpool Gold Dishwasher Shut Off (Dishwasher Repair)
by mwonsala 2/8/2011 9:14:35 AM(UTC)
Whirlpool Gold Dishwasher Help (Dishwasher Repair)
by mrguttz 12/28/2010 12:30:54 PM(UTC)
Whirlpool Gold Dishwasher NOT working properly (Dishwasher Repair)
by Metsno1 8/12/2010 8:42:53 AM(UTC)
no power to Whirlpool Gold Dishwasher (Dishwasher Repair)
by jessejames1075 6/22/2010 8:27:51 AM(UTC)
detergent dispencer door won't lock shut on whirlpool gold dishwasher (Dishwasher Repair)
by hsellman 5/2/2009 9:18:18 AM(UTC)
Whirlpool Gold dishwasher drains (Dishwasher Repair)
by donm 4/25/2009 11:08:46 AM(UTC)
by jfnb10 9/21/2008 1:20:51 PM(UTC)
Whirlpool Gold Dishwasher Detergent Latch (Dishwasher Repair)
by Rob12345 3/16/2008 7:31:12 AM(UTC)
