jakenepa
#1 Posted : Tuesday, April 15, 2008 2:13:40 PM(UTC)
jakenepa
my new oven igniter does not glow. is this caused by a bad gas safety valve?? the igniter is powered up and power goes on and off when the oven themostat is operated but no glow. i jumpered power over to gas safety valve to trouble shoot for bad igniter, before i ordered new igniter so did i cause safety valve failure?
gearhead1218
#2 Posted : Tuesday, April 15, 2008 6:02:16 PM(UTC)
gearhead1218
You absolutely fried the safety valve if you put 120 volts to it.
120 volts is applied to the ignitor. The ignitor has resistance through it, glows and heats up, then with this resistance sends about 3.2 volts to the safety valve to open it.
jakenepa
#3 Posted : Wednesday, April 16, 2008 12:47:35 PM(UTC)
jakenepa
thank you for the response! so the safety valve is fried and now it breaks the circuit so the flat igniter will not glow, even though it has 120 volts supplied to it, the safety valve continues the circuit back to neutral.
gearhead1218
#4 Posted : Wednesday, April 16, 2008 3:37:36 PM(UTC)
gearhead1218
Correct. Basically a series circuit.
Of course when you replaced the ignitor you only touched the ceramic section and wires, right. If you handled the part that glows, replace that new ignitor.
jakenepa
#5 Posted : Thursday, April 17, 2008 5:04:34 PM(UTC)
jakenepa
that is correct i did not touch the element, i ordered a safety valve it should arrive on friday
jakenepa
#6 Posted : Friday, April 18, 2008 2:38:47 PM(UTC)
jakenepa
thanks again for your help! i installed the new safety valve today. the oven is now working!!!!
gearhead1218
#7 Posted : Friday, April 18, 2008 4:31:04 PM(UTC)
gearhead1218
Excellent.
Guest (4)
Gas safety valve - "manual lockout"? (Oven Repair (including Ranges and Cooktops))
by joea99 8/10/2022 3:50:56 PM(UTC)
Oven gas control/safety valve (Oven Repair (including Ranges and Cooktops))
by Michael47 12/5/2020 9:02:49 PM(UTC)
New ignitor draws too much current; will it cause the Safety Valve to not open? (Oven Repair (including Ranges and Cooktops))
by yoyopol2000 8/28/2013 4:58:19 AM(UTC)
Dual Safety Valve Problems (Oven Repair (including Ranges and Cooktops))
by tanders1 7/23/2013 6:25:29 AM(UTC)
Maytag oven slow to light, have replaced igniter and safety valve (Oven Repair (including Ranges and Cooktops))
by kellih 1/23/2013 4:30:54 PM(UTC)
Ignitor/Safety valve problem?? (Oven Repair (including Ranges and Cooktops))
by HkyFrk 11/26/2012 7:37:58 AM(UTC)
new safety valve (Oven Repair (including Ranges and Cooktops))
by smitty11 2/18/2012 3:20:54 PM(UTC)
GE XL44 Safety Valve Assembly Replacement AP2022751/WB19K12 (Oven Repair (including Ranges and Cooktops))
by stefantomoiu 12/13/2010 9:36:04 AM(UTC)
Igniter lights , replaced gas safety valve and over still wont light until you hit th (Oven Repair (including Ranges and Cooktops))
by bigdaddywyatt 12/8/2010 6:32:42 AM(UTC)
Safety valve (Oven Repair (including Ranges and Cooktops))
by philetus 7/19/2010 5:41:58 PM(UTC)
New safety valve large flames in oven (Oven Repair (including Ranges and Cooktops))
by minuteman 1/22/2010 2:10:19 PM(UTC)
Oven safety valve (Oven Repair (including Ranges and Cooktops))
by WALJ 6/21/2009 2:45:59 PM(UTC)
Safety Valve Problem ? (Oven Repair (including Ranges and Cooktops))
by rashaw 4/27/2009 6:50:54 PM(UTC)
GE XL44 Ignitor / burner / safety valve replacement (Oven Repair (including Ranges and Cooktops))
by bhaughee 4/22/2009 3:12:12 AM(UTC)
Help...A Gaffers & Sattler Oven Safety Valve is desperately needed. (Oven Repair (including Ranges and Cooktops))
by AdrienneInNY 11/13/2008 7:41:56 PM(UTC)
