I have a kitchenaid gas oven/range. The oven does not start (neither the broil or bake portion) while the range is fine. I checked several things - the igniters appear to be ok I think. The gas control valve reads 200 ohms between the com and the upper connection, but open between com and the lower connection. Could this explain the oven not working? Is there anything else I should check before replacing the valve? Edited by user Sunday, December 6, 2020 7:21:40 AM(UTC)
| Reason: Not specified
