Julierob
#1 Posted : Sunday, April 13, 2008 3:53:15 PM(UTC)
Julierob
Our Dryer wont turn, When you push the start button nothing happens. Do you have any advice. Thanks
#2 Posted : Monday, April 14, 2008 1:46:00 PM(UTC)
The first thing I would check is 240V at the power outlet (120V between any hot and neutral and 240V between two hot).
If there is no 240V then check the circuit breakers.
If there is 240V then remove the rear cover from the dryer and check the thermal fuse for continuity (#23 on the break down diagram).
If the thermal fuse is open - it has to be replaced together with the cycling thermostat (#24 on the break down diagram).
- The part number for the thermal fuse is AP3132867
- The part number for the cycling thermostat is AP3115922
Here are the break down diagrams for the Whirlpool dryer Model LER3624EQ1
#3 Posted : Monday, April 14, 2008 1:51:57 PM(UTC)
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter – How to check continuity with Ohmmeter.
LG Dryer wont turn on (Dryer Repair)
by stz2 7/28/2021 2:09:54 AM(UTC)
Kenmore Dryer Wont Turn On (Dryer Repair)
by tmurphy12 11/11/2017 5:37:21 PM(UTC)
Dryer wont turn on. Nothing at all (Dryer Repair)
by jim5775 2/7/2013 1:31:10 PM(UTC)
Dryer wont turn on, bulb stays on when door closed (Dryer Repair)
by mazw 7/24/2012 4:21:01 PM(UTC)
Dryer wont turn on, bulb stays lit when door closed (Dryer Repair)
by mazw 7/24/2012 4:13:34 PM(UTC)
by sweetness 6/21/2012 12:24:11 PM(UTC)
admiral dryer wont turn on (Dryer Repair)
by tammy27 6/12/2012 1:08:36 PM(UTC)
by G.A.Russell 2/12/2012 12:42:26 PM(UTC)
by blackcobra427 11/2/2011 9:31:12 AM(UTC)
Roper Dryer wont turn on (Dryer Repair)
by edwardsnl 1/15/2011 12:37:58 PM(UTC)
by snooki 12/2/2010 5:45:01 PM(UTC)
by ritadi 7/4/2010 9:30:53 AM(UTC)
by carri0321 3/29/2010 1:34:12 PM(UTC)
lady kenmore ultra fabric care electric dryer wont turn on (Dryer Repair)
by John414 3/6/2010 7:19:25 AM(UTC)
Frigidaire dryer wont turn on (Dryer Repair)
by gamermom79 1/13/2010 11:15:41 AM(UTC)
