robertson5
#1 Posted : Monday, March 8, 2010 6:36:51 AM(UTC)
robertson5
My dryer works as normal but it makes a squeaking sound off and on when it is tumbling clothes. Googling appears to tell me that it could be a belt (which appears to be fine upon inspection) or the bearings, rollers, etc. Can someone help me out please? Thanks.
sidfink43
#2 Posted : Wednesday, March 10, 2010 10:02:33 AM(UTC)
sidfink43
Go with the rollers and the glides and it is likely you will be all set.
Clean, and I do mean thoroughly clean, everyting inside the dryer while you are in there.
robertson5
#3 Posted : Tuesday, March 23, 2010 9:16:22 AM(UTC)
robertson5
For Sidfink43;
I replaced the rollers, glides, and felt pads and it still squeaks. Albeit not quite as much but it still does it. I throughly cleaned as well as you had suggested. When I was replaceing the parts, I noticed that around soft, furry coating around the drum on the front and back, the front one was partially torn and I don't know if that is causing it to squeak where the drum touches the front panel? Any other ideas? Thanks much for your assistance.
sidfink43
#4 Posted : Tuesday, March 23, 2010 4:52:14 PM(UTC)
sidfink43
I would replace that gasket and see if that does not fix things for good.
Whirlpool Duet Dryer Squeaks / Squeals (Dryer Repair)
by RickG375 1/5/2017 7:08:55 PM(UTC)
Whirlpool Duet Dryer Squeaks/Squeals At Start Up (Dryer Repair)
by damianr418 11/5/2016 6:53:54 PM(UTC)
Dryer squeaks when drum is turning (Dryer Repair)
by Rubenl 10/22/2014 4:14:28 PM(UTC)
GE Dryer Squeaks with wet clothes (Dryer Repair)
by boomerman58 1/14/2013 12:48:06 PM(UTC)
Dryer squeaks loudly after heating up. (Dryer Repair)
by hogman143 6/11/2012 10:50:15 AM(UTC)
GE Dryer Squeaks while running (Dryer Repair)
by slinky75 4/12/2012 11:15:40 AM(UTC)
Admiral dryer squeaks and makes noise (Dryer Repair)
by lormike 3/21/2012 11:26:10 AM(UTC)
Dryer squeaks (Dryer Repair)
by Deraldine 2/6/2011 7:03:48 PM(UTC)
dryer squeaks loudly (Dryer Repair)
by bur831 11/4/2010 2:37:26 PM(UTC)
dryer squeaks (Dryer Repair)
by fipp 5/30/2010 7:42:26 AM(UTC)
by denjean 4/18/2010 6:29:44 PM(UTC)
dryer squeaks and rumbles (Dryer Repair)
by jimmy6571@sbcglobal.net 3/9/2010 2:01:32 PM(UTC)
Dryer squeaks/squeals (Dryer Repair)
by Skuter7199 1/25/2010 4:08:13 PM(UTC)
Dryer Squeaks Loudly (Dryer Repair)
by Tidalflats 12/1/2009 1:49:53 PM(UTC)
Dryer squeaks real loud (Dryer Repair)
by Sheebee 9/28/2009 7:48:09 AM(UTC)
