Recently, it seems that my dishes are not coming out as clean as they used to. It was suggested to try checking the inlet water valve to make sure it's functioning properly. My problem is that I can't seem to find a way to get to it. It's supposed to be behing the lower front kickplate but I can't find screws or any way to remove the kickplate. Any help would be greatly appreciated.
Thank you in advance.
Atreyu
What is your hot water temperature?
Originally Posted by: magician59  What is your hot water temperature? I don't know. I've never measured it. Would knowing that be an indicator of the possible problem? I can measure it and get back to post the results. Thank you. Just a thought. Are you talking about the temperature of the water in the washer during the wash cycle or the temperature of the water in my hot water tank?
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Thank you very much for the information. I will let you know how I fair with it.
