dan b
#1 Posted : Tuesday, March 2, 2010 5:20:49 AM(UTC)
dan b
The dryer was running fine and finished the load of clothes. When the clothes were removed and a new load ready the dryer would not start. By not starting I mean it is dead. There is power to the dryer. Any ideas?
magician59
#2 Posted : Tuesday, March 2, 2010 7:17:51 AM(UTC)
magician59
What is the model number?
dan b
#3 Posted : Tuesday, March 2, 2010 8:26:51 AM(UTC)
dan b
May Tag Mocel # PYE3300AYW
magician59
#4 Posted : Tuesday, March 2, 2010 9:52:14 AM(UTC)
magician59
Your dryer will not run if:
1. The door is open, or if the door switch is bad. (Does the light go off and on as you manually trigger the door switch?)
2. The thermal fuse is "blown", or open.
3. The timer isn't sending voltage to the motor.
The most common cause is a blown thermal fuse. You need to check it for continuity. If it is good, the next thing to check is the door switch. The least common failure (and the most dangerous to check) is the timer.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
