2 Pages<12
#11 Posted : Sunday, February 28, 2010 5:40:10 AM(UTC)
[COLOR="Blue"]if i have continuity at heater and switch do i have a bad control board? [/COLOR]
Not necessarily.
You will see in the tech sheet that one of the door switches is in line with the heater so you also have to check it.
[COLOR="Blue"]if so is there any way to check to see if it bad?[/COLOR]
If all 3 components (heater, hi-limit and door switch) check OK, then measure from W (NO side if door switch or line cord in white) to the board side of the hi-limit when it should be heating. If you do not see 120 volts the board is probably toast.
marko 123
#12 Posted : Sunday, February 28, 2010 6:41:14 AM(UTC)
marko 123
i have continuity at all 3. i took my tester from high limit at board to white wire at door. no 120. i also went to ground and had no 120 at both location. did i understand what i was to do. thanks marko 123
#13 Posted : Sunday, February 28, 2010 6:50:46 AM(UTC)
Yes as long as the unit was in a heating mode you measured it correctly.
Only other thing I can think of to check would be the thermistor resistance.
If it is OK then it sounds to me like your control board is toast.
marko 123
#14 Posted : Sunday, February 28, 2010 7:15:48 AM(UTC)
marko 123
i put in high temp scrub and energy saver dry. no reading. in these modes i asume the white wire is the neutral and the white red wire from high limit should energise board connection so i should be able to get 120 from the board connection to neutral. am i doing the heat right. also where can i find thermister resistance located.
#15 Posted : Monday, March 1, 2010 12:36:29 AM(UTC)
See page 13 in the manual.
Resistance specs are given on the tech sheet
marko 123
#16 Posted : Monday, March 1, 2010 4:04:41 AM(UTC)
marko 123
i found the thermistor resisstance. how do i check to see if good.
#17 Posted : Monday, March 1, 2010 7:09:33 PM(UTC)
Measure the resistance
2 Pages<12
