is the heater high limit under the dishwasher or at the control board
A hi limit cut off would most logically be placed where it can be directly affected by heat. I looked through all the drawings and did not find it; although it is listed in the parts section. I would look first under the tub in the vicinity of the heater. Then, inside the door panel.
i think i found it 1 wire from heater goes to front that looks like a switch off the switch a wire goes to a wire harness going to door the other wire from heater goes to wire harness going into door can i have a part #for that switch so i can look at it thanks marko 123
Here's the part number. To test it, disconnect the wires, and check across the terminals for continuity. Part number: AP3010530
my part dosent look like that if i have continuity whats next the heater has continuity thanks marko 123
There's also a thermistor listed for your model. You never posted your problem. Is it no heat?
clean light keeps blinking wont clear told to check heater and limit switch could be control board if continuity at heat and switch what do you think marko 123
THIS FORUM IS DEAD!!!!!!! |
if i have continuity at heater and switch do i have a bad control board? if so is there any way to check to see if it bad? thanks marko 123
