2 Pages12>
marko 123
#1 Posted : Saturday, February 27, 2010 1:28:50 PM(UTC)
marko 123
is the heater high limit under the dishwasher or at the control board
magician59
#2 Posted : Saturday, February 27, 2010 2:28:49 PM(UTC)
magician59
A hi limit cut off would most logically be placed where it can be directly affected by heat. I looked through all the drawings and did not find it; although it is listed in the parts section. I would look first under the tub in the vicinity of the heater. Then, inside the door panel.
marko 123
#3 Posted : Saturday, February 27, 2010 3:05:51 PM(UTC)
marko 123
i think i found it 1 wire from heater goes to front that looks like a switch off the switch a wire goes to a wire harness going to door the other wire from heater goes to wire harness going into door can i have a part #for that switch so i can look at it thanks marko 123
magician59
#4 Posted : Saturday, February 27, 2010 4:37:35 PM(UTC)
magician59
Here's the part number. To test it, disconnect the wires, and check across the terminals for continuity.Part number: AP3010530
marko 123
#5 Posted : Saturday, February 27, 2010 4:52:17 PM(UTC)
marko 123
my part dosent look like that if i have continuity whats next the heater has continuity thanks marko 123
magician59
#6 Posted : Saturday, February 27, 2010 5:35:04 PM(UTC)
magician59
There's also a thermistor listed for your model. You never posted your problem. Is it no heat?
marko 123
#7 Posted : Saturday, February 27, 2010 6:47:56 PM(UTC)
marko 123
clean light keeps blinking wont clear told to check heater and limit switch could be control board if continuity at heat and switch what do you think marko 123
#8 Posted : Sunday, February 28, 2010 2:44:54 AM(UTC)
marko 123
#9 Posted : Sunday, February 28, 2010 5:07:12 AM(UTC)
marko 123
if i have continuity at heater and switch do i have a bad control board? if so is there any way to check to see if it bad? thanks marko 123
marko 123
#10 Posted : Sunday, February 28, 2010 5:07:53 AM(UTC)
marko 123
2 Pages12>
