[COLOR="Blue"]if i have continuity at heater and switch do i have a bad control board? [/COLOR] Not necessarily. You will see in the tech sheet that one of the door switches is in line with the heater so you also have to check it.
[COLOR="Blue"]if so is there any way to check to see if it bad?[/COLOR] If all 3 components (heater, hi-limit and door switch) check OK, then measure from W (NO side if door switch or line cord in white) to the board side of the hi-limit when it should be heating. If you do not see 120 volts the board is probably toast. |
THIS FORUM IS DEAD!!!!!!! |
i have continuity at all 3. i took my tester from high limit at board to white wire at door. no 120. i also went to ground and had no 120 at both location. did i understand what i was to do. thanks marko 123
Yes as long as the unit was in a heating mode you measured it correctly.
Only other thing I can think of to check would be the thermistor resistance. If it is OK then it sounds to me like your control board is toast. |
i put in high temp scrub and energy saver dry. no reading. in these modes i asume the white wire is the neutral and the white red wire from high limit should energise board connection so i should be able to get 120 from the board connection to neutral. am i doing the heat right. also where can i find thermister resistance located.
See page 13 in the manual. Resistance specs are given on the tech sheet |
i found the thermistor resisstance. how do i check to see if good.
