starkdr1
#1 Posted : Saturday, February 27, 2010 10:05:08 AM(UTC)
starkdr1
During the spin cycle, the belt is slipping and the tub won't spin and I can smell the belt burning as the belt slips. I disconnected everything and turned the unit over. There is a drive belt and a pump belt attached to the motor pulley. There is a lot of play in both belts mainly due to the motor pulley moving laterally. Is that normal? Is there supposed to be that play in the motor? Will a couple of new belts fix me up or do I need to somehow worry about that play? Thanks for whatever help y'all can provide.
magician59
#2 Posted: : Saturday, February 27, 2010 2:38:11 PM(UTC)
magician59
The motor movement is quite normal and necessary. That's Maytag's way of eliminating the clutch. Definitely replace both belts (they normally com in a package together) Part number: AP4011179
. If the squealing and burning persist, also replace the motor pulleyPart number: AP4373024
#3 Posted : Sunday, February 28, 2010 3:17:27 AM(UTC)
You might have something stuck in the tub. Before replacing belts, I would turn the tranny pulley in the spin direction. If very hard to turn, you probably have something in there. Just hinge back the top and remove the tub top and look.
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
Maytag Washer Won't Spin (Washer Repair)
by DJames 9/6/2015 5:36:58 PM(UTC)
Maytag Washer won't spin. (Washer Repair)
by spectre_ 1/19/2015 5:24:12 PM(UTC)
Maytag washer won't spin fast enough (Washer Repair)
by dster 1/6/2014 7:06:08 AM(UTC)
by ProfKenn 11/21/2013 6:18:07 PM(UTC)
Maytag washer won't spin (Washer Repair)
by ma-henry 11/14/2013 8:43:10 AM(UTC)
Maytag washer won't spin and there is a burning smell (Washer Repair)
by figureguy 4/6/2013 11:59:49 AM(UTC)
Maytag Washer won't spin sometimes! (Washer Repair)
by fixit4meNOW 3/21/2013 11:11:25 AM(UTC)
by Hupper 10/10/2011 12:48:31 PM(UTC)
by treehugger 8/25/2011 12:44:37 PM(UTC)
by erichmann 4/11/2011 6:06:40 PM(UTC)
by randowhite 3/31/2011 11:45:17 AM(UTC)
Maytag Washer Won't Spin or Agitate (Washer Repair)
by scott805 11/16/2010 12:09:40 PM(UTC)
