When I push the start button everything comes on, but it makes a buzzing noise and does not heat. I checked the rectifier with a meter and it is open both directions. I also checked the terminals on the magnatron to the magnatron frame and I read 225 ohms. Any Ideas?
Originally Posted by: j2m8pge  ...I also checked the terminals on the magnatron to the magnatron frame and I read 225 ohms... The magnetron is the culprit. No doubt about it. - The magnetron Part number: AP4063394
