dr67
#1 Posted : Thursday, February 18, 2010 5:48:59 PM(UTC)
dr67
lights ,and fan working. you hear a click from a black and white swith mounted on the side of a big black round ball with refrigerant tubes attached to it with a black and a blue wire connected to it. then theres a humm for about 5 seconds then it clicks off. nothing cooling. help please
magician59
#2 Posted : Friday, February 19, 2010 5:41:14 AM(UTC)
magician59
Sounds like a bad start relay. That's the "white switch" you describe.
Qtip
#3 Posted : Friday, February 19, 2010 6:47:01 PM(UTC)
Qtip
yeah i agree 95% of the time replacing the start relay will fix that problem
#4 Posted : Saturday, February 20, 2010 3:23:55 AM(UTC)
The compressor is shutting down on it's overload klyson, most probably a bad compressor, burnt winding or mechanically jamed. It seems like your present start device is working prperly, but without meter data that's just a guess. Let us know if your fridg is older than 15 years old.But it's Worth a try with a start device replacement.
PTC relay 10097202, capacitor C8931608, overload klyson 10377015. The overload klyson is probably ok. Run capacitor C8931608 also probably ok.
dr67
#5 Posted : Tuesday, February 23, 2010 4:35:58 PM(UTC)
dr67
thanks for all your help and advise. great sight to check out. i bought the stater relay and capasitor, installed it, but no luck. it would of been a fast and cheep fix($ 34.00 ). i had a feeling that the compressor was an issue. any idea how much the job goes for and is it worth it ? can i do it ?:confused:
#6 Posted : Wednesday, February 24, 2010 12:23:54 AM(UTC)
This is probably a compressor burnout, big bucks to fix, $500 or more, no way is any fridg worth it unless a Sub Zero.
Amana ABB2224WEB2 freezer and fridge warm (Refrigerator & Freezer Repair)
by aefbae 12/30/2020 10:38:33 AM(UTC)
Whirlpool Defrost not working and freezer and fridge warming up (Refrigerator & Freezer Repair)
by kimberdesi 9/13/2017 12:37:45 PM(UTC)
Maytag WFF2557HEB French Door, Freezer and Fridge Warm (Refrigerator & Freezer Repair)
by Agent0071 10/18/2016 7:13:59 AM(UTC)
by jdrepair 9/15/2012 3:16:03 PM(UTC)
Freezer and fridge warm (Refrigerator & Freezer Repair)
by Ukchris 6/29/2012 10:27:34 AM(UTC)
Freezer and fridge warm. (Refrigerator & Freezer Repair)
by audley 10/4/2011 12:15:02 PM(UTC)
