CILO
#1 Posted : Sunday, February 14, 2010 6:49:45 AM(UTC)
CILO
Hi: I Hard Wired My Cooktop Wrong, It Came On Then Went Out And Now It Does Not Work What Can I Do To Solve The Problem Or Do I Have To Purchase A New One
#2 Posted : Monday, February 15, 2010 2:15:09 AM(UTC)
Replacement parts for E30EC65E models | AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Lassomption/318046813.pdf
First you have to check that the unit is getting the correct voltage.
L1 to L2 should be 240 volts
L1 to Neutral and L2 to Neutral both have to be 120 volts/
Be very careful as 240 volts is lethal.
If OK
Check that a wire has not burned off in the unit.
If OK
Remove power from the unit and check the transformer primary and secondary windings for continuity. Also check for signs of blown components. I do not have what the resistances should be and am unable to get a service manual for this unit.
Perhaps someone else can add this info.
This would be be very helpful as it may give what the voltages should be that come out of the transformer board.
If the transformer is blown or the board looks blown.
Check each of the control boards for signs of blown components.
I would remove P5 from each of the controls and check the resistances between the pins. They probably should be the same on all boards. Here you are just checking to see if one is different from the others re: it has shorted. You do not want to instal;l a new transformer board and have it blow right away.
Be sure to use your meter in both polarities when doing this re: Pin 1 red lead and pin 2 black lead then measure with pin 1 black lead and pin 2 red lead etc.etc.
Write all this down so you can keep track of it.
Cook top down draft vent (Oven Repair (including Ranges and Cooktops))
by Guest 1/22/2023 4:04:02 PM(UTC)
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 9/15/2021 1:11:05 PM(UTC)
kitchenAid Gas Cook top shuts off (Oven Repair (including Ranges and Cooktops))
by kkaiser343 12/6/2017 1:42:16 PM(UTC)
Jenn air gas cook top (Oven Repair (including Ranges and Cooktops))
by Mcalee45@gmail.com 4/18/2017 3:56:39 AM(UTC)
Control Panel not working/oven not working/cook top ok (Oven Repair (including Ranges and Cooktops))
by KarenWallace33458 10/20/2016 5:40:57 PM(UTC)
GE Profile gas, cook top glass #940 (Oven Repair (including Ranges and Cooktops))
by edbabcocko1@gmail.com 1/30/2016 9:12:19 AM(UTC)
GE Cook Top / Sparking from under the knob (Oven Repair (including Ranges and Cooktops))
by nj1971 7/8/2015 8:10:45 PM(UTC)
Jenn Air Cook top Low heat (Oven Repair (including Ranges and Cooktops))
by Curban 9/29/2014 12:14:42 PM(UTC)
Cook top works, but neither bake or broil work and both elements are good (Oven Repair (including Ranges and Cooktops))
by Gene Blake 5/31/2014 7:37:02 AM(UTC)
KitchenAid Electric Range Cook Top no power (Oven Repair (including Ranges and Cooktops))
by coachpelkey 4/7/2014 2:39:46 PM(UTC)
by Robin Morgan 11/3/2013 1:13:52 PM(UTC)
replace cook top (Oven Repair (including Ranges and Cooktops))
by brighten 9/13/2013 3:06:54 PM(UTC)
GE cook top (Oven Repair (including Ranges and Cooktops))
by SKITEXAS 4/14/2013 9:06:19 AM(UTC)
Cook top removal (Oven Repair (including Ranges and Cooktops))
by nickh 3/19/2013 5:40:22 AM(UTC)
Removing Cook Top (Oven Repair (including Ranges and Cooktops))
by Dale Paul 2/20/2013 8:20:18 AM(UTC)
