Rans
#1 Posted : Friday, February 12, 2010 11:52:28 AM(UTC)
Rans
The Dryer stopped heating So I checked the continuity of parts and found the thermal cut-off didn't have any. I ordered the part from you guys in which it also came with the high limit thermostat. I replaced both and it worked for one load then quit heating again. The thermal cut-off now again has no continuity. I made sure the vent was clear both inside and out after replacing the part. No obstructions. Inside the dryer it says this could be caused by a short in the heating element. Can it have a short and still have continuity? How do you check for a short in the heating element? What other steps should I take as to find out the cause of the thermal cut-off activation?
Thank You
Rans
#2 Posted : Friday, February 12, 2010 4:08:40 PM(UTC)
Rans,
Normal resistance reading of the heating element should be 7.8 - 11.8 Ohms. If it's close to zero, the heating element is shorted and will blow the the thermal cut-off.
- The heating element Part number: AP2947033
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL GEQ9800LW1 27"electric Dryer | AppliancePartsPros.com
P.S. The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
Whirlpool dryer won't heat during auto cycle (Dryer Repair)
by Pdcrull 9/7/2014 8:52:29 PM(UTC)
Whirlpool Dryer Won't Heat (Dryer Repair)
by rebecca0101 9/4/2014 10:46:27 AM(UTC)
Whirlpool dryer won't heat (Dryer Repair)
by jev 12/7/2011 5:34:31 PM(UTC)
Whirlpool Dryer won't heat up (Dryer Repair)
by jmrobeck 9/2/2008 10:59:58 AM(UTC)
by haddy 8/14/2008 7:44:34 PM(UTC)
