I HAVE A GAFFERS & STAFFLER ELECTRIC DOUBLE OVEN FROM AROUND THE MID 70'S IS IT WORTH THE REPAIR OR IS REPLACEMENT W/MODERN EQUIPMENT THE ANSWER THE PROBLEM IS THAT THE TEMPATURE IS NEVER RIGHT ,EITHER TO HOT OR NOT HOT ENOUGH:rolleyes:
Check inside the oven to make sure the thermostat probe did not just fall off the mounting clips.
